Testmode problem
By lauamd · Apr 05, 2011in Problems/Troubleshooting💬 6 posts👁️ 1,927 views
Posted Apr 05, 2011 · 13:59 UTC#1
Hi everybody. After few days of searching here and many other places i came to conclusion that i need some help.
starting one week ago i tryed to make my unit boot in testmode. I fallowed the instruction from here but nothing happend. I began with formating the memory card and after i copied the files from testmode.zip (with Winrar), I inserted the memorycard in my avic and turn on the unit. Surprisingly the unit was booting normaly, not in testmode. I try again and again, i formated sd again, rewrite the SD, i've changed the file testmode.zip, i even tryed older version .
Nothing. The unit continue to boot in normal mode. Can anyone help me with this issue ?
Posted Apr 07, 2011 · 01:43 UTC#2
Are you 'unpacking' the files. You can not just take the testmode download and run it. You have to first unpack it. Use winwar or 7zip. You will then have a working testmode (or at least you should have). Hope this helps.
hg
Posted Apr 07, 2011 · 11:51 UTC#3
I did it and nothing.I fallowed the steps in the mods. topic. I think maybe it is something wrong with the unit. The unit reads normal files from card(mp3,mp4,etc.) but don't want to boot.
Posted Apr 13, 2011 · 08:10 UTC#4
Exist the possibility to boot from CD on this model ? <_<
Posted May 04, 2011 · 08:32 UTC#5
After few searches i found one version of test mode who did something on my device. After boot sequence (logo screen) appears for about 1 second a window with a question. I don't have time to read what is on that window :? because after that, the unit enters play mode from previous source. (the SD was formated and had nothing on it)
Any ideea to proceed further ?
Posted Jul 07, 2011 · 19:14 UTC#6
After 3 months i found one version of testmode that works fine.
Thanks for suport .
