I have a 95 Acura Integra and the AVH-3200BT. I have no GPS or other accessories.
The issue I'm having is that the deck turns on exactly when the key gets clicked over to On. Which is normal. The problem is that if I wait more than 1 second and then turn on the car, the deck doesn't seem to get the signal that its on and it won't turn on. Sometimes if I wait a min or two it will just come on by itself. Most of the time I have to turn off the car then turn the key from ACC to ON (fire up motor) with-in 1 second for the deck to come on.
I have the relay from http://www.avhbypass.com, and have tired a Bosch relay from autozone to see if it helped. Same effect. I removed the relay and left the brake cable off, still had same effect. I'm not sure if its a faulty deck so I took it back to best buy and talked to the install tech and he said 'this is normal operation'. I think thats a load of BS to be honest. My wifes 00' civic Si doesn't seem to have this problem at all and I've never had any Pioneer deck that's been installed in this car ever have issues. I've had this car since 98 and I've been through at least 12 different pionner decks with this car.
Any help is greatly appreciated.
