verifying vss is working
By bigc · Apr 06, 2011in Vehicle Specific Wiring💬 9 posts👁️ 5,188 views
Posted Apr 06, 2011 · 22:34 UTC#1
Just installed the 920BT in a 2011 F250. Everything seems to work great.(including mod)
I Connected the VSS to the Black and Grey wire in the radio harness(pin #4). My question is: how do I know that it is corrrect?
Also, do I need to hook up the reverse gear wire if I don't have a rear view camera?
Thanks for the help
Posted Apr 06, 2011 · 22:48 UTC#2
Look under Navi Settings -> 3D Status
No, you don't need reverse.
Posted Apr 06, 2011 · 22:50 UTC#3
WOW that was quick - Thanks
Posted Apr 06, 2011 · 23:42 UTC#4
Calibrated speed should match speedometer?
Posted Apr 07, 2011 · 01:31 UTC#5
Not necessarily. You have to keep in mind that your speedometer is not 100% accurate. There are factors (including tire size variance) that determine what your speedometer thinks you are traveling vs what you actually are. Typically GPS is a more accurate reading.
Posted Sep 09, 2013 · 02:37 UTC#6
Can we skip this step and just relay on gps signal
Posted Oct 06, 2013 · 04:24 UTC#7
of course you could, but why be lazy?  you should just hook it up so the unit is as accurate as possible.
Posted Jan 04, 2014 · 14:30 UTC#8
hello
Posted Jan 18, 2014 · 00:48 UTC#9
Get the plug and play harness from Enfig.com . They are very knowledgeable and you don't have to hack up your cars harness. I have a Audi and found it ridiculous to have to search for a random wire behind my fuse panel for a vss wire. Crutchfield should have it together enough to supply people with the correct harnesses. Christian from Enfig will supply you with the correct harness.
