Issue with GPS
By CatalinT · Apr 07, 2011in Problems/Troubleshooting💬 2 posts👁️ 695 views
Posted Apr 07, 2011 · 11:55 UTC#1
Hello,
I would like to know if anybody has experienced any problems with the GPS when starting up. Here is the situation.
I upgraded to latest firmware. After that i have installed Abb's mod. I did not noticed this until the day after i have installed. When i start my car, my GPS is offline. Is like searching and searching. This can take up to 5 min or so. Usually i drive off and after a while it finally comes online. When it connects everything looks ok. The problem exists only when the car has been parked for a while. Like a couple of hours or so, and every morning. I did not had the time to go back and format and reinstall the original software. I can also mention that i did not had this problem before the upgrade, and wonder if any1 else has been experience problems like this.
Does anybody has any idea how i can fix this ?
Cheers
Catalin
Posted Apr 12, 2011 · 15:41 UTC#2
if this didnt happen before you modded the system, then you should really try to go back to your backup.
