My new 920bt and my iphone 4 connects bluetooth np but i have no contacts and they dont sync and i can't add them.Also the contacts folder never lights up?
Iphone4 and 920bt
Pull your parking brake.
+1
Already did that,thats why i am asking why it does not work
What happens when you manually press transfer contacts?
It says send buisness card by operating phone and sits there forever or you cancel
Contacts never lights up,even on the phone it has a setting to sync contacts,phone works
fine,bluetooth works i just have no contacts,have to manually call.Works great on my x710bt
just don't understand why i am having probs with my new 920bt.
You're supposed to hit cancel on that box (it's for older phones). It should then transfer in the background within a few seconds.
Maybe the iphone is paired as audio and not handsfree? Have you tried repairing the two?
How many contacts do you have?
Have you tried turning on/off the iphone?
Yes i did hit cancel nothing happens,i deleted phone and paired again still the same.Only have between 20 and 30 contacts and if all else fails turn off iphone
this is why i posted here.
I tried again last night deleted and re paired and it does say iphone conected as audio device but phone works and when i hit hands free it says
device alreday conected but still no contacts and everytime when i hit add contacts it wants me to send buisness card i hit cancel and nothing
even have on the handbreak,am i missing something?I have read for hours
To answer my own question restore brand new 920bt to defaults and all is well,hope this helps someone
never thought you would have to do this to a factory fresh new unit.
Not the same but similar issue, on mine when my Iphone 4 connects none of the contact icons are active (Transfer Contact, or Contact) bith are grey out.
I have seen at a couple occasion the "Tranfert Contact" icon becoming active just after my phone connects but then goes back grey.
The phone works fine through the radio, I can initiate and receive call through the Avic, can even play music via bluetooth,
I have tried "un-pairing" and "re-pairing"the phone and no change.
Allso checked the Bluetooth setting of the phone, it sees the Pioneer AVIC and if I go in the details everything regarding contact is enabled.
Any idea what this could be ?
PS I have not done 2.003 update yet..
I am no expert but i would upgrade to 2.003 see if that fixes the problem.Then if that does not work i
would hit the button restore to factory defaults worked great for me i was going out of my mind trying
this and that and asking questions reading the manual and such,but i had the same problem i could oerate the
phone but everything else greyed out.Hope this helps
