gps wrong and ipod songs x920bt
By hikneeken · Apr 09, 2011in Problems/Troubleshooting💬 5 posts👁️ 1,432 views
Posted Apr 09, 2011 · 23:15 UTC#1
i recently purchased a used avicx920bt. the map shows the location of the last owner which is about 30 miles away from me. I noticed the gps antenna doesn't have the metal sheet. Does that make a difference? Is there a part number or somewhere i can order? The gps wire is also not a constant flow of wire, there is near the antenna the wire is cut and held together by electric tape... i am safe to assume the factory did not do this? Is there somewhere i can buy the entire gps antenna, part number?
Also the ipod takes forever to load(as in never does fully load), i have 13000 songs. Is this a common problem? How can i speed up the load?
Posted Apr 10, 2011 · 03:00 UTC#2
U only need the metallic pad when you're placing the antenna where obviously no metal underneath it. Check ebay for GPS antennas, they sometimes have OEM ones.
Posted Apr 11, 2011 · 15:10 UTC#3
am i supposed to modify current location on the x920bt after buying it used or is the unit supposed to update itself if the gps is working?
Posted Apr 14, 2011 · 00:12 UTC#4
You can set the Home location anytime you want.
Posted Apr 19, 2011 · 20:57 UTC#5
as soon as the system has a GPS lock, it should update your location to the correct place.
