Back up Cam Install on bmw X5 not working
By Maxx0831 · Apr 11, 2011in Problems/Troubleshooting💬 13 posts👁️ 3,855 views
Posted Apr 11, 2011 · 03:32 UTC#1
Hey everyone, I just finish install the z130bt into a 2006 bmw x5. I hooked up a regular back up cam to the HU, just its not showing up when switched into reverse.I know the reverse cam works because I plug the video cable to the AV1 and it works and, also when its plugged into the brown cord when I can split the screen. Im getting 12volts power from the where the radio gets power I guess ACC. I hooked up the purple signal wire and ran it to the positive of the reverse lights, but I dont see a picture automatically comes on. The volts from the reverse light are about 10.4 volts. Could that be the problem? Like I said, reverse cam works but not automatically when switched to Reverse.
Posted Apr 11, 2011 · 03:39 UTC#2
Did you check the setting for the cam on the radio? I believe there is 2 settings u can change. ON/OFF and 12V/GND
Edited Apr 11, 2011 by rgarjr
Posted Apr 11, 2011 · 03:42 UTC#3
The setting I checked was under reverse cam settings I believed. It said Reverse cam " on and off " and Polarity "Power or Ground" I have it for On and Power for both settings.
Edited Apr 11, 2011 by Maxx0831
Posted Apr 11, 2011 · 03:46 UTC#4
check the purple wire and make sure it is getting 12V when in reverse. Also would be a good test to apply 12V and see if the radio switches to rev cam mode.
Posted Apr 11, 2011 · 03:51 UTC#5
Yeah, go into connection status and make sure the avic is getting the reverse signal. It should change from "Low" to "High"
Posted Apr 11, 2011 · 03:51 UTC#6
I checked the purple wire but its gets 10.4 volts. When the car is switched into reverse I only get 10.4 volts. Could that be the problem?
Posted Apr 11, 2011 · 03:53 UTC#7
Ill look for Connection status on the Avic. I dont remember seeing that option. I was just frustrated all day i
Posted Apr 11, 2011 · 03:54 UTC#8
it should be around 12V, but go ahead disconnect the purple wire and temporary hook up battery 12V to it, to see if the cam comes on.
Posted Apr 11, 2011 · 03:56 UTC#9
ok, so what your saying is disconnect the purple wire from the reverse lights and hook it up directly to a 12volt battery to see if it comes on?
Posted Apr 11, 2011 · 03:58 UTC#10
yep
Posted Apr 11, 2011 · 04:00 UTC#11
alright thanks, Ill give it a try first thing tomorrow and let you know
Posted Apr 11, 2011 · 12:40 UTC#12
BTW, I doubt that the difference between 10.4 and 12V matters to the backup sensor circuitry, but there is something wrong with your wiring if you only get 10.4 volts when your car is running. Your car is running, right?
Posted Apr 12, 2011 · 02:18 UTC#13
ok guys, I checked the connection status and its low in park and high in reverse. It worked once and after that it stopped. and in the connection status it went from high back to low. So I disconnected the purple wire from the reverse lights and hooked it up to the battery and it works perfectly. i tried like 5 times. I did a search about back up cams with bmw and people were saying that our cars don't give a 12volt at reverse and how its a pulse signal so we need to wire a relay but before i go into that i wanted to chime in here first.
Edited Apr 12, 2011 by Maxx0831
