Hello all,
I have a 2008 Navigator and I am looking at getting the Z130BT, especially since I see that they are no longer using MSN. Before I purchase I am going by the dealer to see if my truck qualifies for the SYNC kit since they make one for select '08 Navigators, but if I can't get the sync kit added I will get the Z130BT. No USB or bluetooth audio is killing me.
Ok let me give you the setup, right now everything is factory, it has the voice navigation THX system with the amp, sub, Rear Seat entertainment, sirius, and backup cam in the rear view mirror. I want to replace the factory head unit with the Z130BT and limit the functionality loss. I know I will need the PAC C2R-FRD1 for CAN-BUS, VSS, etc and the SWI-PS for the steering wheel controls but:
1. Don't I need some type of adapter for the factory AMP?
2. If I decide to replace the factory amp with an aftermarket one is there some type of harness to ease the transition like the PAC AOEM-FRD24?
3. I noticed that all of the adapters that I look at only have 4 channels, but the truck has 9 speakers that I know of plus the sub.(The Lincoln website says 14 speakers, idk where????) (One in each door(4), Two in the front near the side rearview mirrors (2), one in the center (1), and two in the rear above the rear hatch (2), plus the sub). So how would the other five+ channels & sub be incorporated?
4. I also think I will need an Antenna adapter for the radio antenna and for the sirius, is this true?
5. I like the rear camera in the mirror but was wondering if I could also have it display on the radio at the same time? I may have to tap into some wires for that.
6. Will I be able to use lincoln's built in mic for voice commands on the Z130BT? It hears me alot better than the one on the Z110BT in my wifes car.
7. Will I lose my voice activation steering wheel control button?
8. Will the radio volume mute/lower when the backup sensors go off or is there something special needed for that?
Thanks in advance for all the help team.
Chris
