Xm check antenna
By Jacksworld718 · Apr 12, 2011in Problems/Troubleshooting💬 2 posts👁️ 1,162 views
Posted Apr 12, 2011 · 19:16 UTC#1
I recently changed from a avic 110bt to the new z130bt I plugged in the xm wire from the adapter and still het check antenna I don't believe it's a xm antenna I had it up and running in my old radio
Posted Apr 19, 2011 · 14:41 UTC#2
So, let me get this right...you're old unit said check antenna, you got a new unit and it still says check antenna?
Check antenna, from experience (7 years worth), typically means the antenna is shot. They are $30, but a new one, if it's not return it.
The other large category is the XM tuner is bad (rare with the direct adapters).
