how to edit image.res
By vectrex · Apr 16, 2011in Completed Mods/Themes💬 6 posts👁️ 3,259 views
Posted Apr 16, 2011 · 14:28 UTC#1
Hi,
I tried a few editors after using google, but non will work with the images.res file.
What editor should i use to replace files in the image.res file?
Edited Apr 16, 2011 by vectrex
Posted Apr 16, 2011 · 15:44 UTC#2
Hi,
I think you just use 7 zip to extract, could be wrong tho
Posted Apr 17, 2011 · 08:12 UTC#3
7-zip works. I could access the files with winrar but couldn't write back.
Thanks.
Posted May 14, 2012 · 19:41 UTC#4
7-zip does work and you can convert back to .res
Posted May 19, 2012 · 11:59 UTC#5
My 7Zip won't let me convert the file back to .res anymore, it just stays as .7z all of a sudden. Anyone know why?
Posted May 19, 2012 · 12:43 UTC#6
if you are using windows, no need to open 7zip, just right click on the folder you want to convert then select 7zip, add to archive. you need to change the file extension from 7z to res
