z130 settings help
By amp3d · Apr 17, 2011in General💬 6 posts👁️ 1,323 views
Posted Apr 17, 2011 · 19:24 UTC#1
Hey guys,
I just updated my z3 to the new z130, but am having trouble finding certain options in the menus (everything has been moved around).
- how do I fix the map so it won't spin? (north always UP)
- preset re-naming? Is there a way? (instead of just P1 etc)
- custom menu on the left side (remove unused sources from left menu on audio screen) possible?
- AHA radio only seems to be usable if controlled by the iphone...cant be controlled by the deck? (audio comes through though)
- is there a way to view XM signal stregth?
Posted Apr 17, 2011 · 20:16 UTC#2
Hey guys,
1. The red/white compass icon.
2. No
3. No, but it should only show available sources.
4. Yes, it's controlled by the AVIC, not sure what you're doing wrong.
5. No
Posted Apr 17, 2011 · 20:56 UTC#3
Thanks for the info.
One other thing thought, I'm not getting any audio from the gex-p10xmt which I used before. Reports on here say it worked with the z110 and 120s. Do I need to order a new 920?
Posted Apr 17, 2011 · 23:18 UTC#4
The gex-p10mt works fine on the Z110-Z130.
Posted Apr 18, 2011 · 12:20 UTC#5
Well, I talked to XM to make sure everything is working right, and I get all the channel data ie song titles and everything, but get NO audio on the 130 with the p10xmt :(
I'm not sure if its my headunit that is the problem or the xm receiver itself...any suggestions?
Has anyone actually tried the p10xmt with the 130 or did you guys just use it with the 120 assuming it will work on 130?
Edited Apr 18, 2011 by amp3d
Posted Apr 18, 2011 · 18:37 UTC#6
I've used it on a Z110, Z120, and a Z120 upgraded to Z130.
