Pioneer AVIC F930BT X930BT
By Ralpharn · Apr 18, 2011in Hacks/Mods💬 21 posts👁️ 29,923 views
Posted Apr 18, 2011 · 13:59 UTC#1
Here is a link for torrent file. Just cut .txt at the end of the file. Manuals and File structure.torrent.txt
AVIC-X930BT_Service_Manual_EN
CX-3250_Service_Manual_EN
Folders structure:
NDATA (map and other files)
NDB
SD (sd slot)
SD2 (empty)
SD3 (empty)
SD4 (empty)
USB (usb conector)
USB2 (empty)
USB3 (empty)
USB4 (empty)
USER (main applications are here)
files that visible from testmode missing NDATA folder (Main applications are here, in \USER\PRG0\Apl)
NDATA folder complete (with US map):
Part1
Part2
How to replace maps on our units read here.
Edited Jun 26, 2012 by Ralpharn
Posted May 12, 2011 · 19:43 UTC#2
Thanks for the uploaded data mate!, i will start making tests to add the Mexico Maps. NICE!!!
Posted May 13, 2011 · 20:05 UTC#4
Hey man thanks for the advice about the hacking method and thanks for the link was pretty helpfull!!, i'm currently trying to locate the map folder(s) if any in order to place the "fbl" (Mexico_83_TA_2009.09.fbl)Mexico Map files files that i have from my current iGo system-based car stereo, at this point i can only guess they could be different extensions or another kind of map files because until now i was unable to find something similar to the tele atlas fbl files i have. Maybe they are navteq, any idea or clue will be very helpfull and of course i will post the whole procedure once i figure out how to do it. Thanks for your help once again. Cheers!
Posted May 16, 2011 · 12:56 UTC#5
... i'm currently trying to locate the map folder(s) if any in order to place the "fbl" (Mexico_83_TA_2009.09.fbl)Mexico Map files files that i have from my current iGo system-based car stereo...
Unfortunately new units like ours X930BT do not use IGO anymore. So it is impossible to use IGo maps with this new official Navi.exe. Condi managed to run IGo (and I did same) but GPS port seems blocked. and we need to figure it out how to free GPS port. So keep on watching at that thread.
Posted May 24, 2011 · 22:13 UTC#6
Hello Ralph, just to keep this post alive i want to inform who may concern i haven't had any luck yet trying to placing Mexico Maps they are just installed on a very different file system. Anyway i'll keep trying. Cheers!
Posted Sep 01, 2011 · 06:34 UTC#7
You need software from your local F220 or similar.
Posted Jan 25, 2012 · 19:30 UTC#8
mauleon, did you get something with your Mexico map?
I live in Panama and I´m trying to get functional my X930BT, I used to work with a Garmin Nuvi, I even got the sd card map for it.
I´m wondering if I could use it somehow with my Pioneer unit.
Raul.
Posted Apr 22, 2012 · 14:02 UTC#9
Ralpharn, when I click on the "NDATA without MAP" link, it says the file is missing :?
Posted May 04, 2012 · 16:45 UTC#10
hello,
how can I reset the avic f930bt ? please help me !!
Posted Sep 13, 2012 · 16:42 UTC#11
You need to block runing originally F930BT or X930BT gps app, which continue to make busy gps port (serial com port), that's reason why iGO8 can see that port, it's not blocked, it's just busy (used), with original gps app, you need to discover which app use gps port, .exe and to rename iGO8.exe in title of that app, or to make some unlock, which will run diff. shell, and then to rename igo8 exe to title of originally gps app .exe
Posted Sep 19, 2012 · 08:09 UTC#12
Take a look here. it looks like it blocked on windows bootup level. So Pioneer's software has nothing to do with keeping this port busy. We need to check windows files that running in hackmode v1.2 You know where to get that old hackmode do you? ;)
Posted Sep 21, 2012 · 01:15 UTC#13
does anyone know do u have to hook up the reverse gear wire and if u dont are you missing anything
Posted Sep 21, 2012 · 03:38 UTC#14
Not needed unless you have a backup cam.
Posted Mar 29, 2013 · 10:19 UTC#15
HI, can anyone please seed the torrent (or just share the TTSDATA folder) ?
TIA
Posted Apr 28, 2013 · 10:47 UTC#16
Hello,
I need help on the F930BT (eu) , I made update of my radio reception ,but i made a mistake and now i have black screem...
i can even turn on no light nothing after my update , so i want to know i could i do ?
just help......
steven
Posted Jun 25, 2013 · 19:40 UTC#17
TIA
Hey Frisk,
you may want to look here,
http://avic411.com/index.php?/topic/35601-cnsd-310fm-eu-2012-update/
I have the TTSDATA folder available on the first post of that thread. :-D
Posted Jul 30, 2013 · 16:13 UTC#18
hi,
thanks for your offer but no thanks.
got it for free so... :mrgreen:
by the way, if anyone of you need a lost TTS voice, I can provide these FOR FREE (just PM me) :
CZC, DAD, DUB, ENG, FIF, FRF, GRG, HUH, NON, PLP, PTP, SPE, SWS, TRT.
Posted Aug 14, 2013 · 03:58 UTC#19
Can someone please start seeding?  I got about 55% done and now there is ZERO people seeding.
Posted Aug 17, 2013 · 19:24 UTC#20
If someone could please seed then I should be able to finish up and then I will leave this thing seeding all the time.  Thanks.
Posted May 10, 2014 · 15:07 UTC#21
Hey guys can you please seed these files again i only got to 1% and it stopped downloading...
