Install in 04-08 F150
By cltgt · Apr 25, 2011in General💬 5 posts👁️ 2,454 views
Posted Apr 25, 2011 · 20:53 UTC#1
If anyone has installed a double din unit in a 04-08 F150, which dash kit did you use? I do not like the Metra Turbo Kit for this model vehicle. Guess I will have to keep playing around with it to see If i can get it to look right. Thanks.
Posted Apr 27, 2011 · 16:21 UTC#2
what dont you like about the metra kit?
i've never had a problem with the 99-5815
Edited Apr 27, 2011 by 1loudls
Posted May 01, 2011 · 14:00 UTC#3
I put one in an 04 F250, I think you have the same dash. The factory radio was not quite double din so required a little triming of the dash opening and a metra 99-5805. Like you I wasn't thrilled with the Metra kit, you might try the pioneer kit ADTVA133, they are about $40 on Amazon
Posted May 03, 2011 · 01:55 UTC#4
Not to fond of the Metra double din kits.. I have gone through two of them and they keep breaking around the notch areas on the sides....
I now have the Scosche double din in my F-150... I like the design better. Got it at Walmart. Can't beat the price...
http://www.walmart.com/ip/Scosche-2004-Up-Ford-Double-ISO-DIN-Kit/10752515
Posted May 04, 2011 · 19:01 UTC#5
not quite, the 04 super duty's still used the old school ford radio where the body of the radio is smaller than the face and the opening is not quite a double din, the 04 F150 was the first year of the redesign, and used the new "bigger than double din" radio's so they are completely different kits
