AVH P4300DVD Crossover Question
By BIGTACO · Apr 26, 2011in Pioneer AVH Series💬 2 posts👁️ 1,275 views
Posted Apr 26, 2011 · 19:06 UTC#1
I just finished installing my P4300DVD HU and need a little help with setup. Does this unit have seperate crossover capability per output channel?
I am running my sub and front components off dedicated amps both with built in crossovers, but my rear speakers are running straight off the HU. I need to set high pass filter on them but can't seem to find per channel crossover on the menus.
Does it exist?
Posted Apr 26, 2011 · 19:17 UTC#2
I have not seen a per-channel crossover, but I have used the high-pass filter which I believe is dedicated to only the front and rear outputs. You will probably have to set the filter on the HU and adjust the crossover for your front's seperately.
