930BT duplicate song file issues (the dups start with a period & underscore)
By Zoomaddict · May 12, 2011in Problems/Troubleshooting💬 16 posts👁️ 4,908 views
Posted May 12, 2011 · 03:31 UTC#1
Problem: Micro SD card with folders of music (greatest hits albums) in .mp3 format. About half of the folders on the card appear on the 930BT screen with duplicate song names, like this:
01 Rockin' Into The Night.mp3
._ 01 Rockin' Into The Night.mp3
02 Lie to Me.mp3
._ 02 Lie to Me.mp3
These duplicate files do not appear on the SD card or when played from iTunes. Need to fix these files from the computer if possible (even if deleting all the files that start with "._" is possible from the head unit in the car the music on the SD card is changed frequently).
Tried all I can think of to get rid of these phantom files (that all start with "._"). Willing to give anything a shot so please post your ideas. Just found 411, thanks in advance for the help guys!
Edited May 14, 2011 by Zoomaddict
Posted May 14, 2011 · 05:44 UTC#2
Top picture illustrates the problem, about half of the albums appear like this. Bottom Picture is how the rest appear (there is no problem with these).
Any potential solutions please post and will give'em a try. Thanks!
Edited May 15, 2011 by Zoomaddict
Posted May 19, 2011 · 03:54 UTC#3
Problem: Micro SD card with folders of music (greatest hits albums) in .mp3 format. About half of the folders on the card appear on the 930BT screen with duplicate song names, like this...
These fantom failes probably came from playlists. Check do you have *.m3a or other playlist files in folders.
Posted May 19, 2011 · 14:22 UTC#4
Thanks for the response Ralpharn. Unfortunately the only files in each folder are the actual .mp3 files (and the invisible "DS STORE" file that the Mac OS uses).
Still on the hunt with this one!
Posted May 20, 2011 · 02:38 UTC#5
Can you play these 'phantom'files?
playlist can be not in the folder. As test try to rename folder that has duplicated files. just add something to folder name. Also check does this folder contain anything except mp3 files. Do not forget hidden and system files. %)) Also playlist can be *.m3u
Edited May 20, 2011 by Ralpharn
Posted May 23, 2011 · 03:13 UTC#6
Phantom files cannot be played, they do not exist. It just skips all the phantom duplicates in the song list (the ones starting with a period and underscore) and the message "skipping unplayable files" appears for a couple of seconds at the bottom of the screen.
Renaming the folder is a good idea, but did not resolve the issue.
None of the folders contain anything except the actual .mp3 files (there are no .m3u or any other file types in any of the folders).
Thanks again for the suggestions, would really like to run this glitch down!
Posted Jun 05, 2011 · 05:17 UTC#7
Still have not run this issue down (yet). Some of the things I've tried:
- Problem isn't with the folder (same problem with files w/o folder put on root of disk).
- Problem isn't with file names (changed to "test" and "1").
- Problem isn't with the SD card: Reformatted to (FAT32) and tried a different Card (8GB and 16GB capacities).
- Problem isn't invisible files (all folders have same .DSSTORE and Spotlight files but only half have the problem.
- Problem isn't other files (no .3mu playlist files, or any file types except the .mp3 files).
- Changed the names on the disk and each .mp3 file to things like "testsong" and "testdisk".
- Double-checked that these files are not DRM protected.
- Used iTunes to convert the problem .mp3 files to AAC files.
- Used iTunes to convert the problem .mp3 files down to 128 bitrate.
- Used a different converter (not iTunes) to reduce the bitrate to 128.
- Used a file tool to insure the file type/creator/lock/etc info for the problem files is the exact same as non-problem .mp3 files.
- Spent quite a bit of time attempting to locate a solution on the net (Am I really the only one with this issue??).
None of this has eliminated the phantom files. What baffles me is all this music plays fine in iTunes and on other non-Apple mp3 players, and only about half have the problem when displayed on the X930 from an SD Card.
If anyone reading this has potential solutions to try I'd love to give them a go. Thanks!
Edited Jun 08, 2011 by Zoomaddict
Posted Jul 06, 2011 · 05:00 UTC#8
two additional ideas:
1. what OS you uses on computer used for file upload? sometimes files deleted under Ubuntu visible under Windows.
2. ID3v1 and ID3v2 tags... some files can have them both. But player should handle such things...
Posted Jul 06, 2011 · 14:00 UTC#9
Using a Mac Pro running 10.6.8 (most current version of OS X).
All tags are ID3v2. Some have been converted up over the years, though I cannot see where this could cause the issue. All songs are fully tagged and uniform (all have the same tags so they appear correctly on most any mp3 player I've ever used (up until now).
Have ordered a USB flash drive to see if the problem persists when this interface is used, but would still like to determine what causes the phantom files when using the microSD cards as these are preferred storage (smaller & have camera that uses microSD as well).
Posted Jul 08, 2011 · 20:33 UTC#10
Same issue when played from a new USB flash drive. Hard to believe no one else has run across this problem.
Edited Jul 08, 2011 by Zoomaddict
Posted Jul 12, 2011 · 19:52 UTC#11
Those files are created when you copy certain files from a Mac OS X disk to a non-Mac formatted drive, such as your SD card. More info here.
You basically need to delete them on the computer before putting the SD card into your radio. You can search around on the web for links to scripts to delete them. There's also a Mac terminal command called "dot_clean" that may help.
Posted Jul 15, 2011 · 19:18 UTC#12
Thanks for the reply joeyalex. Was not my problem directly (deleted files were being recreated by a mirror drive before I was able to eject) but did lead me to a solution. Now the head unit moves from file to file much quicker, the forward/back steering wheel controls work (they didn't anytime they hit a phantom file), and the random works as it should (it would turn off anytime it landed on a random file and had to be turned back on manually). Thanks again for the post!
Posted Feb 02, 2012 · 08:29 UTC#13
So @Zoomaddict, what was the solution, because I was having the same issue.
Posted Mar 30, 2012 · 22:31 UTC#14
I am having the same problem with mp3s added to USB drive on OSX - any suggestions on how to remove them? I searched re "dot_clean" and the discussion re how to use it is way over my head . . .
Posted Mar 31, 2012 · 02:51 UTC#15
Reformat the SD card under the Windows environment and see it the problem goes away.
Posted Jul 13, 2013 · 14:02 UTC#16
Was a fix ever found for this? Its happening to me too. I have OSX in my house and no windows pc
