I have a Z110BT that has been flashed to a Z120BT. I recently purchased the Sirius modules for it (Sirius to Pioneer interface and the Sirius receiver). I hooked up everything up and can see the channel I am on as well as what song is playing, but there is no audio. I thought it may have been the Sirius equipments, so I replaced both of them but same problem. This leads me to believe that it's the Headunit. Any ideas?
No Audio from Sirius
Posted May 14, 2011 · 05:59 UTC#2
which Sirius receiver are u using?
Posted May 14, 2011 · 15:52 UTC#3
The receiver is the SCC1 and the interface to the HU is CD-SB10
Are those the correct part numbers?
Posted Oct 31, 2011 · 11:29 UTC#4
I had the same issue, I had to disconnect the power to both the sirius and head unit, for about an hour, tried 15 minutes and still didn't work. I thought the unit was broke, but after having battery disconnected for over an hour, It worked again. I have also called both companies about this issue, and they had told me the Sirius unit was bad.. But I guess they where wrong.
But a month later I decided to go with the XM unit, due to its better interface..
Posted Nov 24, 2011 · 03:25 UTC#5
I had the same thing and ended up finding the cable was in the wrong slot on the cd-sp10. It needed to be in the output slot instead of the input.
