2006 Expedition Avic D3 Install
By jimb726 · May 14, 2011in General💬 4 posts👁️ 1,579 views
Posted May 14, 2011 · 04:11 UTC#1
I bought a used 2006 Eddie Bauer Expedition, with Rear DVD and no factory nav. it came with a Avic D3 installed, I had been having problems with it and upon removal it appears that whoever did the install did a very poor job and there are several loose wires that look like they were connected at one time but are no longer. I guess I am looking for 2 things, which wire is the VSS and which is for the reverse signal on the factory harness and if I am not installing a camera, do i even need to worry about the reverse one?
Thanks in Advance.
Edited May 14, 2011 by jimb726
Posted Aug 02, 2011 · 17:22 UTC#2
those wires are probably not at the factory harness if the factory radio was non-nav
No
Posted Aug 02, 2011 · 18:38 UTC#3
My 2008 F-150 had a vss sensor wire up to the factory radio since it had speed volume control.
Edited Aug 02, 2011 by dos0711
Posted Aug 02, 2011 · 23:10 UTC#4
then he may have luck if his radio had that option
