Splash Screen Sizing
By amajr316 · May 18, 2011in Custom Backgrounds💬 10 posts👁️ 7,151 views
Posted May 18, 2011 · 17:29 UTC#1
Hello all. I have an f90bt, and no matter how hard I try, I cannot get any of my backgrounds to size properly. I have tried 500x240, 800x384, 1000x480 - but to no avail. What ends up happening is that when I am browsing the folder, the image appears to fill the screen. Then, it 'svaes' to the system. When I fire up the car again, the photo is centered int eh screen, and it probably about a quarter size of the viewable area. I found my way here as I have the system in my Subaru Outback - but I can repost anywhere! Thank you for your time.
I welcome any and all suggestions!!!
Posted Jun 02, 2011 · 03:37 UTC#2
same issue here, does any1 have a solution? thanks!
im using the 500x240 which is recommeneded and suggessted but the picture is just dead centered in the screen
(using z130bt
Edited Jun 02, 2011 by onesickGS
Posted Mar 28, 2012 · 15:33 UTC#3
Still hoping to find a solution. I have used all 'recommended' settings that I could find for the splash screen both on this forum and on the web - but still no actual working solution.
Thank you!
Posted Jun 16, 2012 · 21:36 UTC#4
I have this same problem, could someone who knows what we are doing wrong please help us?
Posted Jun 16, 2012 · 22:48 UTC#5
I have spent some time with this today, i found if i unlink the aspect ratio of the image i can size length and width independant of each other.
To fill my F700 screen i need 780 x 480, which depending on image used works well or NOT.
I'm very new to this so i don't really understand the techniques of resizing these images correctly
Thought this might help
Posted Jun 24, 2012 · 19:43 UTC#6
Try this, should work in theroy...
Look at the default image size...The one you replaced with your new pic...
then make yours just like that.
Good luck.
Posted May 22, 2013 · 18:25 UTC#7
First of all, make sure your image is 72 dpi (dots per inch)  this is a setting in Photoshop under image size.
An LCD monitor of any type can only output 72 DPI, any "extra" pixels are discarded by the monitor and the
resulting image is anyone's guess.  I had a similar problem with my F series AVIC system even after resizing,
so what I did was to put the image on a black background.  That way, even when it didn't fill the screen, it looked
good.
Posted May 26, 2013 · 11:26 UTC#8
600 x 480.
Posted Aug 07, 2014 · 11:43 UTC#9
I used 72 dpi & 800 x 480 pixel size on my AVIC F940BT this morning and it came out really nicely
Edited Aug 07, 2014 by cdt808
Posted Aug 31, 2014 · 14:47 UTC#10
good.
 I haven't attempted to load a custom splash screen yet, but I am well acquainted with digital graphics...
72 dpi setting has nothing to do how an image is displayed on a screen.  It is either displayed at the screen's native resolution, pixel for pixel, or it is scaled, i.e. pixels are interpolated to whatever number of pixels it appears on the screen. How the latter is accomplished is dependent on the rendering engine (can be either hardware or software, or both).
Another issue is the screen's pixel density is not the same both vertically and horizontally.  For example, I have loaded a custom splash screen on a Kenwood DNN990HD... and while it has an 800×480 display, the vertical and horizontal pixel densities are different.  When an 800×480 image is loaded, it gets stretched horizontally...
I have a 8000NEX which has an effective display area of 156.6mm × 81.6mm (exactly the same as the Kenwood DNN990HD).  Divide those dimensions by 800 and 480 respectively, then divide the former result by the latter and you get 1.15 and change.  So to get the display to show an image that is not stretched horizontally, the image has to be created at 921×480 pixels, then shrunk horizontally to 800×480 pixels.
