F900BT not saving aux settings
By sam i am · May 21, 2011in General💬 4 posts👁️ 1,428 views
Posted May 21, 2011 · 08:10 UTC#1
Anyone know how to sort this?
Every time I start my car, I have to go to audio settings and change AUX 1 to ipod. Turn car off - this setting is forgotten.
Pretty annoying..
Pretty sure it's not saving my radio settings also!
Edited May 21, 2011 by sam i am
Posted May 27, 2011 · 20:54 UTC#2
Who wired the head unit?
Sounds like there is no constant hooked up. Perhaps the guy tried to wire it to be on all the time, but instead, wired it so that it's only getting power when the ignition is on.
100% your wiring. Fix it.
Edited May 27, 2011 by casemods
Posted May 30, 2011 · 16:30 UTC#3
constant has to bee hooked up for the unit to power up at all, but it does sound like it is not hooked up to the right source, the yellow wire at the back of the radio needs to see 12+ all the time (this is what keeps the memory settings) the red wire needs to see 12+ only when the key is on, it is very possible that you have these hooked up in reverse, pull apart and test with a meter to verify.
there are a few car where the constant and ACC wires are switched in the aftermarket harness (older Mercedes for example that use the VW harness)
Posted May 30, 2011 · 16:59 UTC#4
Was wired by my local garage, who clearly did it wrong. I'll get it sorted by someone who knows what they are doing.
Cheers for the advice guys - really appreciate it.
