Sound problems F9210BT
By Yusuf · May 21, 2011in Problems/Troubleshooting💬 5 posts👁️ 1,588 views
Posted May 21, 2011 · 18:43 UTC#1
Hey guys.
I've recently bought a pioneer F9210BT for my WV Golf mk5, i've installed it. and everything seems to be working.
But when i connect my phone with the parrot ( BT ) device on the 9210BT and make a phone call. I get no voice but the other end can hear me, same thing happens when navigating.
The usual annoying voice won't direct me.
Is this a known problem or just my failure on the connection of wires?
Thanks for you help in advance.
Posted Jun 19, 2011 · 21:37 UTC#2
Same problem here :(
Let me know if you've found a solution pls.. I have a scare idea, that maybe it's because I use an amp (by the phonocables) to drive my speakers... and maybe (god forbid) the nav/phone audio only goes through the standard speaker output.
Posted Jun 19, 2011 · 21:44 UTC#3
i'm assuming that you both have checked all of the volume setting (on the phone as well as the AVIC's)
Posted Jun 22, 2011 · 12:40 UTC#4
Found the problem :-$
I'm only using a 2-channel amp at the moment, and had connected the source from the REAR channel ... where there's NO nav/phone audio.
Everything is working perfectly now.
Posted Jun 22, 2011 · 14:06 UTC#5
yup that will do it, glad you got it figured out.
