Hey everyone I have a avic -d3 bulletproof unit since i bought it only problem was when I upgraded nav disc with disc from ebay ... then glitches started fixed with new original disc upgrade solved that .. not to my current problem ... I got rid of my iphone and with that iphone i had no problems using the phone features and playing media like music through the pairing of the iphone by bluetooth through y bluetooth adaptor from pioneer... well i switched to android and I am using the LG G2X ... when i pair the phone through bluetooth the phone features work through the stereo but for some reason the bluetooth audio is not paring and I cant get it to work for the life of me !!... this was one of my most favorite features to use on my stereo and I am ver disappointed .. what can i do here ??? is there and upgrade for software for the head unit ? ... or what can I do ? ... I hate using the aux input on the headunit because I get feedback while driving and it sounds like crap ? please guys and gals what can I do to be able to play media through bluetooth with my LG G2X and y avicd3???
AVIC D3 ... PROBLEM PLAYING MEDIA THROUGH BLUETOOTH
Did you get ur problem resolved I have the same issue can anyone help please
I have the same problem same thing wirpth no sound from my iPhone 3GS can anyone help please
I still have not solved this problem and very surprised no one has anything to say about this ... is there anyone out there witha a solution to this problem ???
wow I guess no one has an answer to my question ?
seriously there has to be a way to play music through my avic d3 using the bluetooth audio feature ?! if it worked with my iphone 3gs then it should work with the LG G2X ... has anyone out there had this problem and solved it ... and once again I am able to connect my phone through blue tooth and use the calling feature but I cant play music from my phone for some reason ???
Hi guys,
I have a lg 2x(the brother of the G2X) and had the same problem, bluetooth audio couldnt connect. So i found a fix for it
What you need to do is the following!
Go on your device(if you have android) too connections. Put bluetooth on and then scan for devices under bluetooth settings. Add the pioneer BT unit and you will see that calling works but audio not.
How too fix this?
Press on Pioneer BT unit and hold your finger. Then click on "options", you will see that there are 3 options
Option 1 is called "Connection"
Option 2 is called "Phone"
Option 3 is called "Media"
You need too disable "phone". Connection and media should be enabled!
Bluetooth audio on the avic d3 will find your phone now and you can listen too music!
When this worked you can enabled "phone" agan so both functions work(i haven't tested this part very well)
Let me know if it worked for you! Works fine for me!
weebeast it worked perfectly fine and yes if you check the phone feature afer the media connection is working the call feature works also ... thank you soo much you are a lifesaver !!!!!!!!
Hehe good that it worked for you. Enjoy ![]()
will this also work for iPhone?
Hi guys,
How too fix this?
When you say "Press on Pioneer BT unit and hold your finger," do you mean pressing your finger on the phone or pressing it on the Pioneer head unit?
