Vehicle/Deck info
2007 Toyota Tundra CrewMax
z120bt
Kenwood XR5S
Last night I replaced all the door speakers, added 12 inch sub and into my Tundra.
I have had my z120bt in my truck for a couple of months. During those months I added aftermarket oem fog lights to my Tundra with DDM HID's. Everyone has been working fine.
During the testing of the install the radio/amp/speakers all were running fine.
After buttoning everything up I turn on my fog lights and the system goes dead. Amp is turned off and my z120 while it appears to be "on" is not pushing out any audio almost like it went into a protect of sorts.
Turning the truck completley off and back on resets everything and it will all work fine as long as the fog lights are not turned back on.
My headlight use the same HID's and do not cause any trouble. The fog lights do have a relayed harness because they were installed aftermarket even though they are "oem".
I am trying to figure out how I can bypass the harness to try what fixed VBLUE42 issue found in this thread:
I am not sure if VBLUE's fix will correct mine but I am at a lost currently as to why this is happening. Any help would be greatl appreciated.
