Looking for 2005 350Z speed signal wire
By gbodey · Jun 13, 2011in Problems/Troubleshooting💬 3 posts👁️ 1,382 views
Posted Jun 13, 2011 · 05:53 UTC#1
In searching the forum, I have found two answers for the speed signal wire.
1. Is it the white wire in the white connector on the back of the A/C control box
2. Or the white wire on the middle gray connector with silver markings on the wire.
Note: there are actually three white wires on the middle gray connector, one has gray marks, one has a black line and one has a green line.
This is for the 2005 350Z.
Posted Jun 15, 2011 · 23:29 UTC#2
i have a 2003 Z i hooked mine to the white wire on the middle gray connector worked fine for me. Im not sure about the silver markings on mine there was a pink dot every inch or so.
Posted Aug 29, 2011 · 15:05 UTC#3
you should use a DMM to test and verify which wire is the VSS.
