Well I am almost finished my install. I still have the ND-BT1 and the Wireless remote to install... should be here this week. Wanted to say a BIG THANKS to DucatiBoy!!! Your bypass works like a charm!
Here is the problem I am having. I have installed the Z1 into a 2005 Chevy Optra (similar to the Suzuki Forenza) and I am having troubles with the VSS wire.
I went to the local GM Dealer and asked them to print me out the schematics for the VSS wire on my car. The printout said that it is the D-GN/WH wire. I located the wire coming from the engine through the firewall below the drivers side. I noticed that there were two same color!
I tested one with a volt meter on AC/V and when I was stopped I would get a reading. I then started to move the vehicle and it would move a little, but not a lot. I then tried the other and I got nothing.
I hooked up the first wire and went into the Z1 settings to check the connection. When I am in park I get 200 as a reading (in the Z1 connection menu). When I move it stays the same.
I then tried the other wire and it didn't give me a reading at all.
My questions are... does anybody know the right wire? and what should I look for on my volt meter when I am testing wires?
p.s. I will post pictures of my install some time next weekend.
TIA
Posted May 23, 2006 · 04:06 UTC#1
