AVIC-D2 questions
By nhmtns · Jan 14, 2007in Problems/Troubleshooting💬 4 posts👁️ 1,086 views
Posted Jan 14, 2007 · 03:16 UTC#1
I'm having trouble with a few features on the AVIC-D2 I had installed recently. For some reason, some options aren't highlighted so I can't select them. For example, I can't adjust the look of the vehicle dynamics display.
Is there something I'm not doing right? Why aren't all the features available? Thanks.
Posted Jan 14, 2007 · 03:21 UTC#2
Unless you installed a bypass your parking brake has to be on for all features to work .
Posted Jan 14, 2007 · 03:35 UTC#3
Hmmm, I'm pretty sure that's not the problem because I've been sitting in my parking lot with the parking brake on trying to figure everything out. I also can't change the background of the Navigation or AV.
Is there a chance that something wasn't installed correctly?
Posted Jan 14, 2007 · 05:04 UTC#4
Go into the connection status screen. Make sure that when you set and release the parking brake that the unit says off and on when you do this. The car may have to be running though. Some cars, mine for instance, will say the parking brake is on even with it off unless the engine is running.
