So many popular XM logos are missing on the AVIC. Jason pointed out that they are missing because XM changed the names of those channels. This occurs on any AVIC, any XM receiver, and both NAV disks 1.0 and 1.2.
There is a file called TABLEDAT that has the XM channel names listed, and it maps them to the XM logo PIM files. For example, 'SquiZZ xL' is listed in this file. However, XM recently changed the xL channels to list xL first, so now the receiver gets 'xL SquiZZ'. This is not in the TABLEDAT file, so you end up with the stock satellite logo.
Open TABLEDAT with a hex editor such as HackMan. Find the channel name and switch it around with xL first. That's it! It works fine.
I haven't gotten the channels that changed their name completely to work yet, but I will get to that.
By the way, you need UltraISO to make a ISO copy of the DVD, then change the files. You will also need a Dual Layer DVD+R to burn the fill CD. However, you can make a standard DVD+RW if you delete the huge POI files first. We need sticky on how to create the modded DVD...
Derek
Posted Feb 22, 2006 · 16:24 UTC#1
