custom backgrounds help
By nhmtns · Jan 15, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,143 views
Posted Jan 15, 2007 · 00:27 UTC#1
I've tried twice (unsuccessfully) to make custom backgrounds following the steps in:
http://avic411.com/forum/viewtopic.php?t=38
Steps 1-5 work fine, but I'm confused by step 6: "Once the iso making is done, open the image with a ISO Editor, such as UltraISO."
UltraIso can't open it. I can add the .PIM files I made, but when I burn the DVD it doesn't play in my AVIC-D2.
What am I doing wrong?
Posted Jan 15, 2007 · 02:42 UTC#2
Just when iI think I've figured it out, I try to burn onto a DVD and find out there isn't enough space. I need 5.9GB and I only have 4.7GB. Gonna have to go buy some new DVD-R's with more capacity.
Posted Jan 15, 2007 · 02:48 UTC#3
You'll need dual layer dvds or you'll have to delete some files. The tutorial tells you how to finle the files you need to delete to burn a single layer dvd.
Posted Jan 15, 2007 · 21:32 UTC#4
Ok, so I got an 8.5GB dual layer DVD and burned everything. My AVIC-D2 doesn't read it. :(
What's going on? Can someone please help? Thanks.
Posted Jan 16, 2007 · 23:33 UTC#5
Well, I finally got it to work. I added two images but only one works. I used Alcohol to burn the ISO on a dual layer DVD.
