I transferred my z1 from an f150 to an f250 and now all my options are greyed out when I get above 5 mph
All the gps and phone options any suggestions?
Thanks ahead of time
Check your bypass.
Could you please explain bypass
So you don't have the bypass? How were you able to use those functions while moving before? Anyway there is plenty of info on this forum about the bypass if you search for it.
Might help if you posted the question in the Z1/2/3 sub-forum. This is for Z110/Z120/Z130. The bypass method is different - I believe.
Good catch Ron, moved.
The grey options indicates the following:
1. If not bypassed and hooked up using factory instructions, then set your parking break to un-grey the options. If this does not work, then your parking brake wire on the Z is not properly connected to the parking break.
2. If you are using the bypass to allow full functionality at all time (even while driving), then your parking break wire from the Z is not properly grounded. See the sticky post in hacks section for bypass instructions.
BTW, if you moved it from one vehicle to another, you need to reset all 3D calibration settings so the unit can recalibrate from scratch.
