z120bt iphone 4, delay to hear either end of a call
By Islesfan79 · Jul 16, 2011in Problems/Troubleshooting💬 3 posts👁️ 791 views
Posted Jul 16, 2011 · 01:58 UTC#1
Hi All! I've had a hell of a time with the install of this new system, mostly due to an suicidal installer that went on stress leave for a month after installing my stereo and didn't do it properly. It's finally sorted, but I've got one issue with it I'd like to see if there's a fix for.
I'm finding when I make or receive a call using bluetooth on this device that there's a good 4-5 second delay after the connection is made where no one can hear each other - after that it's totally fine, but it's causing people to hang up in the first few seconds thinking I'm not there, and I can't hear them either initially.
This was bought off the showroom floor and was up to date (bluetooth 3.11, firmware update 2.003) but I didn't reset it to factory settings.
Is this common with this system or is there a problem? My iphone 4 is updated to the latest os and the connection is great, once it actually kicks in.
There is also no ringer while I'm making a call, just an icon that shows me it's dialing and then when the connection is made, not sure if that's normal either.
any ideas or suggestions?
Posted Jul 18, 2011 · 14:30 UTC#2
no ideas? This can't be normal can it? Everything else on the unit is working well, but this delay connecting to calls is becoming a pain.
Posted Jul 21, 2011 · 14:37 UTC#3
Solved!
here's what I found. I'm in a nissan versa hatchback, 2009 SL with the bluetooth and xm radio and the upgraded stereo option (obviously still wanted a touch screen and gps)
I noticed yesterday when getting into the car that the light for a bluetooth connection for the factory stereo (top of the car, near the interior lights) was still lighting up when I started the car, despite the fact my iphone was showing it connected to the z120bt. turns out I had connection still with BOTH.
I deleted the factory bluetooth from my iphone and everything now works perfectly.
