D3 speaker issue
By jegonzo3 · Jul 18, 2011in Problems/Troubleshooting💬 5 posts👁️ 1,726 views
Posted Jul 18, 2011 · 17:44 UTC#1
About one month ago, my D3 started having issues with sound to the front left speaker. If I turned the volume up, sometimes it would work, sometimes not. I thought it was blown, so I bought a new pair for up front, needless to say, same issue.
Now, it's happening on the right front also. The rear speakers are working just fine. Just so you all know, I am running this all through a 5-channel amp.
Has anyone else had any issues with their D3 like this?
thanks,
jegonzo3
Posted Jul 26, 2011 · 20:11 UTC#2
a little more info needed, like what kind of vehicle is this installed into,
its either going to be the outputs of the radio are dead, the cables carrying the signal are bad, the amps channels are going out, or the wiring from the amp to the speaker is either shorted or broken.
Posted Sep 22, 2011 · 16:00 UTC#3
Sorry for the delay, I didn't get notified of a reply.
This is in a 2006 Nissan Frontier.
If I take it into a shop, will they be able to run diagnostics on both the D3 and amp?
Posted Sep 22, 2011 · 17:59 UTC#4
any good shop shouldn't have any problem troubleshooting the issue and finding a solution.
Posted Sep 23, 2011 · 04:19 UTC#5
You cannot swap D3 outputs, say front to the operating rear to see if it is the amp channels or the head unit? The layout of some multichannel amplifiers makes proper cooling of one or more sections less effective, which might cause the typically harder driven main L and R to fail first.
