X930BT bypass and VSS problem
By rubenhak · Jul 26, 2011in Hacks/Mods💬 6 posts👁️ 4,026 views
Posted Jul 26, 2011 · 18:52 UTC#1
Hi everybody,
Recently got my X930BT installed in a body shop, very happy with it, but of course nothing in this world goes 100% smooth.
So I asked those guys to do the bypass, and also specifically insisted on having VSS wire connected.
However, when i look to connectivity menu(that's awesome pioneer made it available for users) I always see my speed pulse set to 0 (even when the vehicle in motion).
So, i'm not thinking if this is expected and after doing the bypass it makes the unit think that it is not in the motion and does not pull out/display speed sensor information? Or it is not connected properly?
Thanks,
Ruben
Posted Aug 04, 2011 · 20:11 UTC#2
They probably didn't hook up the vss wire. I installed mines a few weeks ago and did the bypass and just left the vss wire alone. Speed input is 0 just like yours but everything works while i'm driving.
Posted Sep 09, 2011 · 19:01 UTC#3
all it does is turn volume up with speed? care?
Posted Sep 09, 2011 · 20:36 UTC#4
Nope, supposed to track vehicle movement if GPS signal is lost (tunnel, tall buildings, etc) until the GPS can hook back up
Posted Oct 20, 2011 · 03:22 UTC#5
to the OP did you ever figure out if they just did not hook up the VSS wire properly or if it was hooked up and something els was going on ?
Posted Nov 02, 2011 · 18:21 UTC#6
Hi everybody,
Thanks,
Ruben
I've got the same thing. They did a bypass but did not connect VSS (property) even though I insisted on that. I've also used to purchase and provided a module that would pull out VSS signal from CAN-BUS interface and that helped a lot. Once connected properly I did not see any problems. It works flawlessly!
