Z2 Re-Installation Problems
By clush · Jul 28, 2011in Problems/Troubleshooting💬 4 posts👁️ 1,389 views
Posted Jul 28, 2011 · 01:36 UTC#1
My uncle gave me a Z2, so I used my general head unit knowledge (as well as lurking on these forums a few times) and installed it in my 2003 civic LX. I had the GPS velcrod on top of my steering column, right behind my wheel and for a couple months it worked fine. During installing I accidentally connected the z2 illumination wire to my cars dimmer (knew because the dimmer knob controlled the brightness) so I decided today to fix it, as well as move my GPS to my trunk, and also connect my new sirius radio to the aux audio input. So I do all that fairly easily, and now I have a few problems and I can't seem to find out why.
1) I didn't get a parking brake error as usual, but after moving for ~30 seconds it popped up and locked me out. I read on This bypass guide that if that happens, the connector 2 (wire #2) isn't connected properly. I extended the light green parking brake and connector#2 wires with some generic copper wire, drilled a screw directly into the chassis behind where the headunit sits, and grounded both wires under the screw tightly - not sure what is causing the issue.
2) *edit* ***The calibration was just taking awhile. Just went driving and it is working fine.***I reset the 3D calibration since the GPS was moved to the trunk, but it didn't even locate me until I got back home from where I was working, which is about 3 miles. Under the status menu when driving it says, "excessive vibration". Granted, I never really looked in there while driving, so it may have said that before - not sure if that is playing into why the GPS is not locating me even though it has 2 bars and 5-7 satellites.
3) The only audio input I saw on the entire unit was connector #1s red/white RCA "audio input" cords. My sirius radio uses a 3.5mm jack, so, I bought a 3.5mm to RCA cord. I connected the RCA to the Z2, electrical taped them so they wouldn't disconnect, turned on aux input in settings, and plugged in my iphone - nothing. iPod - nothing. Sirius - nothing. Clueless as well on why this didn't work. The only 3.5mm hole anywhere on the z2 or any of the connectors is a "wired remote input", which definitely has nothing to do with auxiliary.
4) I would like to connect the VSS, but I have no idea how hard it is or where the wire even is in my car. Haven't looked much in-depth in this, but any direction would be helpful.
I know this is a large thread with multiple questions, but any help is appreciated. Thank you.
Edited Jul 28, 2011 by clush
Posted Jul 28, 2011 · 13:40 UTC#2
1. go into the hardware settings and see if 'parking brake' shows 'on'. If so, your ground is good so you need to check wire #2 at the back of the headunit. If not, then the grounding location you used is not a chassis ground.
2. Press the reset button, and it may clear the 'excessive vibration" warning.
3. It's not 'aux' input. You are using the 'A/V input'. Try that source and you should hear your sirius radio.
4. I found some info on the VSS for 2003 Honda Civic:
SPEED SENSE - white/green - PCM ( I do not know where the PCM is located in your car)
The vss is in connector A (31 pins), pin 18.
If you have cruise control: The vss is also blue/white at the cruise control module to the left of the steering column.
Posted Jul 28, 2011 · 20:07 UTC#3
1) I'm thinking it is the wire#2 in the actual connector that is the problem because while I was doing the bypass I asked my Dad, who knows a ton about cars, if the steel bar running horizontally behind the dash was part of the chassis and he thought it was. That is where I drilled my ground screw.
2) The GPS is working fine now, so I don't think that message was causing the gps to not work - was probably just calibrating slowly from the reset.
3) I found this out late last night and everything works :) thank you
4) I also looked around and found that it is a blu/wht wire on the ECU behind the glove box. Not sure which is the correct one.
Posted Jul 28, 2011 · 21:19 UTC#4
1. The only reason that I think it could be the ground is because you stated that you did not get the parking brake error warning. If the problem is only the second wire, I would expect the parking brake error. Good luck!
