Just had a new Z130BT installed to replace one that was damaged when someone tried to steal it from my car. I had no trouble pairing my and my wife's Droid Eris phone with the original unit. However - my new Droid Incredible 2 won't pair and connect and neither will my old eris or my wifes eris. The unit recognizes the phones - and lists them on the headunit - the phones list the Pioneer Navi but when I pair - I get a "can't communicate with Pioneer" message. WTF?
I could see the new Incredible 2 not pairing because it's a relatively new phone - but the Eris's worked no problem before.
I sure hope it's not the Z130BT being defective.
Help!
I never follow the exact steps listed in the manual. Well, I did once - and it didn't work. Specifically, I never use the "Nearby Device List". I think it only works with some devices. Try this:
0. On the AVIC, go to BT settings/Registration.
1. On your phone, delete the old pairing.
2. Also on the phone, put it into scan mode (exact terminology will vary).
3. On the AVIC, press "Register from phone". The "Please follow the instructions on your phone" box will pop-up.
4. On the phone, you should eventually see the HU name listed. If it doesn't (sometimes it takes more than one try), hit Cancel on the HU and go back to step 2.
5. On the phone, select the device name of your HU. Should prompt you for the HU's password. Enter it in the phone's keyboard (or touchscreen).
6. Also watch for any other prompts on the phone - like asking it it is OK for the HU to access the phone-book.
7. I think that's it. I'm writing this from memory, so I don't have exact details.
I have done it this way with many phones - Win and Android. Like I said, some require more than one try. Might be a good idea to reboot the phone so you know you are starting clean - no interference with an application still running in the background.
BTW, I always rename the AVIC to something less generic than "PIONEER NAVI". Probably a good idea to change the default password from "1111" too.
