Netflix?
By trancemode · Jul 29, 2011in AppRadio, AppRadio 2, AppRadio 3💬 8 posts👁️ 6,047 views
Posted Jul 29, 2011 · 11:26 UTC#1
Hello,
I just got my Appradio and am having an issue trying to get Netflix to work.
I know AppRadio doesn't support Netflix on their recommended apps however
I have seen and heard people getting this to work.
Got display out but everytime you quit Appradio you get this annoying message to "release handbrake" and "do it again"
and press "OK" however the OK never lights up.
Any ideas?
Thanks.
Posted Jul 29, 2011 · 11:45 UTC#2
I found that the parking brake warning would pop up at some really unnecessary times so I ran the PB safety wire straight to a toggle switch and then to ground. Whenever the message pops up I just flip the switch.
Posted Jul 29, 2011 · 12:03 UTC#3
is there any alternative except running a toggle switch?
I believe I tried to bypass it grounding it.
Posted Jul 29, 2011 · 12:49 UTC#4
you can't just ground it because you have to release and engage the brake. in this case, a switch is your best solution.
Posted Jul 30, 2011 · 11:23 UTC#5
ah i see. Is it different compare to those F700 bt models?
Never had to get a toggle switch before for that one.
Posted Aug 21, 2011 · 16:28 UTC#6
I can't seem to get Netflix to display at all. I head audio but no picture comes across.
Posted Aug 21, 2011 · 23:31 UTC#7
Which iPhone do you have?
Posted Aug 24, 2011 · 20:34 UTC#8
Once you have the parking brake issue sorted out, just be sure you're in app mode on the head unit. In other words, be sure you've pressed the Apps button from the AppRadio home screen and that the parking brake (physically or via a switch wired to simulate it) has been toggled on/off/on.
