Problem with Pioneer AVIC-X1R
By KIMVSR · Jul 29, 2011in Problems/Troubleshooting💬 4 posts👁️ 11,696 views
Posted Jul 29, 2011 · 17:16 UTC#1
Hi,
I'm from Finland and I'm happy to have my Pioneer AVIC-X1R, but I have a big problem:
When I use my navigation system I can't use the "search adress" button. It is dark and not "touchable" )=
Of course, I'm using original navigation DVD with East Europe maps, and there is a Finland map to.
I can see my location on the map, but I can't enter adress to search menu.
I have tryed to write a new navigation DVD (CNDV-100MT), but it's not working.
The system show me "Please insert the appropriate disc".
My original DVD is CNDV-50MT Europe (East).
Could somebody tell me, what's the problem?
Thanks guys and sorry for my bad english (=
Edited Jul 29, 2011 by KIMVSR
Posted Aug 05, 2011 · 09:55 UTC#2
Ok, your problem ist either you have written the dvd with a wrong program.
For the best result burn on a dvd-r DL, i use verbatim dvd´s and they work exellent, be sure to have - dvd´s not plus.
What you can try is a full factory reset, it works mast times, if not than try to do a rewrite of your dvd.
What i also find out is that your laser unit has to be cleaned, i had the same problem with a friends avic, afther cleaning the laser it worked well.
a complete factory reset works like this ;
Remove disk
Hold reset and eject
Release reset but hold eject
Screen will go back in and out-then says please press the reset button ... don't
Then with joy pad press...
up,right,up,right,down,right,down,right…then ok (joypad button inwards)
Password screen will come on screen breifly
Test mode screen apears - click joystick to right once
Scroll down to number 6 - program forced write (ok)
Find number 1 system program (insert disk --cndv 40/50/60?)
Press 1 system program (ok)
Select 2 dvd/cd rom (ok)
Select language… (english)
Press (view –pos) button
Should see system program going up in %
When finished press (back)
Find number 6 program forced write again (ok)
Number 3 application program (ok)
Select 1 uk english...then press (view – pos) button
Should see system going up in %
Test mode page 1
Select 6 - clear back up memory (ok)
Should say finished then asks for reset button to be pressed
Press reset on front of unit
Start sat nav again
Askes for language press no (read text)
System starts
Buttons
Ok = joypad inward
Back = joypad to the left ... note this will bring you back to previous page
Back = band button ... note this will take you back to the main menu
Edited Aug 05, 2011 by ttmanx
Posted Aug 07, 2011 · 20:31 UTC#3
Remove disk
Test mode page 1
Start sat nav again
System starts
Buttons
Ok = joypad inward
Big thanks for you! I will try this and write here about results..
Posted May 02, 2013 · 22:21 UTC#4
On avic x1 I cant seem to select the language and load the firmware it just beeps at me and does nothing :(
It has [en] next to it, am I missing something or not doing something??? I'm proper stuck!
