930BT bypassed but buzz sound.
By mkimjoon · Aug 07, 2011in Problems/Troubleshooting💬 2 posts👁️ 1,227 views
Posted Aug 07, 2011 · 06:16 UTC#1
Hi enjoying my 930bt here so far! Before the bypass i wasn't able to set up anything since parking wire wasn't grounded. After the bypass mod, everything works fine now, i can set up everything. However, there seems to be a buzzing sound from the speaker and it gets louder when speeding up. I'm sure it's prob a ground issue? but i followed through that youtube vid where you have to connect all the 3 wires together? What could be causing the problem? Any solution to it? Thank you!
also is there anyway to hack to show asian lang instead of ????
ty!
Posted Aug 08, 2011 · 14:08 UTC#2
if you are getting an alternator whine, one of more of the fuses inside the unit may have blown.
