Using the rear audio rcas to put an aux/3.5mm port?
By JFarhanbod · Aug 11, 2011in General💬 4 posts👁️ 1,622 views
Posted Aug 11, 2011 · 05:49 UTC#1
is it possible?
using something like this
http://www.amazon.com/RiteAV-3-5mm-Stereo-Female-Cable/dp/B0018MI5F6/ref=sr_1_2?s=electronics&ie=UTF8&qid=1313041627&sr=1-2
or
http://www.amazon.com/RiteAV-3-5mm-Stereo-Male-Cable/dp/B001S0LUCI/ref=sr_1_3?s=electronics&ie=UTF8&qid=1313041654&sr=1-3
My reason for not using the front one is that it doesnt work. (never has)
and if those do work, how would i activate it so i can hook it up to my ipod and get music playing from it?
Posted Aug 16, 2011 · 15:56 UTC#2
doesnt the D series have a video input, if so then this is where you need to connect the cable, and you would have to use the second cable linked to as the first one will not connect to the females
RCA's on the back of the unit
then you select the video input as the source, most units this will need to be activated for it to function.
Posted Aug 16, 2011 · 17:18 UTC#3
Why not just get the ipod cable if your wanting to hook up your ipod?
Posted Aug 17, 2011 · 14:16 UTC#4
i have seen some people that just dont like the ipods interface, and find it easier to just access the music from the device itself
