110->120 update screen issue
By vypr · Aug 12, 2011in Problems/Troubleshooting💬 1 posts👁️ 909 views
Posted Aug 12, 2011 · 04:39 UTC#1
hey all,
I am pretty sure this is not the case but thought I'd ask anyhow.
I updated my 110 to the 120 software. everything went fine untill after the last BT flash.
It completed the flash and said to hit OK. I did and then hit eject sd. the screen dropped I reached in to pop out the sd card, and just as I pushed the sd the screen started back up!!
It got jammed on the sd and now will not close all the way, it will halfway close or the tilt icons will "flutter"
I have done all the resets and nothing works, some times when I turn off the car the screen will close but when I turn it back on the screen will not respond at all.
Any ideas?? If it IS screwed any ideas on what part to replace?
