GM olive XM antenna to typical pink XM antenna
By silvergxp · Aug 14, 2011in XM/Sirius/HD Radio and Traffic Receivers💬 3 posts👁️ 2,659 views
Posted Aug 14, 2011 · 17:39 UTC#1
this next weekend, I'll be installing a new avic-x930bt along with an existing (installed in another car) gex-p930xm into a Pontiac Solstice I recently bought. It comes with stock xm and want to use the existing xm antenna. However, the existing GM XM antenna has an olive colored plastic end with three fins spaced equally instead of the typical pink xm antenna.
looking for suggestions on making it work. I would also like to be able to take the gex-p930xm out of this car and back to it's existing car on occasion (i.e. when driving the other car for extended amounts of time instead of the roadster), so would want it's plug to stay as is.
I've seen the pink plastic end pieces sold on ebay but didn't know how well I could swap out the existing olive colored for the pink and still have it make a good connection. My first instinct is to add some extra groves to the inside of the olive piece so it fits with the pink and use tape to ensure it stays tight to the pioneer xm tuner.
thoughts or suggestions?
I've also seen this adapter that might work with less dremeling
http://www.xm-radio-satellite.com/fakra_adapter_cable_for_sirius_xm_smb_antennas_smb_fka.aspx
Edited Aug 17, 2011 by silvergxp
Posted Aug 16, 2011 · 20:47 UTC#2
Easy.
Use a razor knife and trim the protrusion on the pio xm tuner sat port. Then it plugs right in.
Theres no special adapter, tools, dremel needed. Trim the XM tuner antenna port and plugs the factory antenna right in.
One swipe with a razor knife and your good to go
Edited Aug 16, 2011 by gtsdohcvvtli
Posted Aug 17, 2011 · 15:25 UTC#3
good! as long as the clicker part of the conx works in both, that sounds perfect.
The HU and wiring harnesses ordered should be here today, so should have it all put together this weekend!
