AVIC x930bt not turning off
By kubyanobya · Aug 29, 2011in Problems/Troubleshooting💬 2 posts👁️ 1,667 views
Posted Aug 29, 2011 · 02:56 UTC#1
Hi,
I was wondering if anyone of you could help me figure out a problem w/ my new AVIC x930bt. I am trying to install it in a '04 grand prix and I have followed the instructions to a T and also double and triple checked my work. However, what is happening is as soon as I plug the harness into the factory harness the AVIC will turn on and my car is off and keys are not in ignition. I just replaced a AVIC-N2 and using the same harness and it worked fine, so I know this harness is fine and it has to do with how I'm wiring the stereo to the GMOS-04. Any help would be appreciated.
Posted Sep 23, 2011 · 19:27 UTC#2
well if you have confirmed that the ACC signal IS shutting off coming out of the GMOS (red wire) and you are sure that it is wired up correctly, then you must have a defective unit.
