Day/Night Setting on Z130 Nav - Not Working
By IndyDave · Sep 08, 2011in General💬 6 posts👁️ 1,472 views
Posted Sep 08, 2011 · 14:53 UTC#1
Hi, I'm new to the forum but wanted to see if anyone else has this problem. I have a Z130 and while I've set it to automatically change from Day to Night view on the map screen settings, at night the map will only ever show the "Day" view. IOW, I can't get it to flip to the "Night" view. It's pretty distracting driving at night with the Map Screen displayed this way.
How does the Z130 know to display day or night views?
I have successfully done the firmware update (I have 3.001 installed at this time) and it did the same thing before the firmware upgrade and after.
Thoughts?
Thanks, Dave
Posted Sep 08, 2011 · 16:22 UTC#2
Thoughts?
Thanks, Dave
It sounds like your illumination wire isn't connected properly.
Posted Sep 08, 2011 · 17:03 UTC#3
Also, make sure your Day/Night Display setting is set to Automatic. See pg 161 in the Z130 manual.
Posted Sep 08, 2011 · 17:35 UTC#4
Thanks, I've verified that it's set to Automatic. I'll have to check on the illumination wire (meaning, have my installer check).
Posted Sep 27, 2011 · 19:32 UTC#5
I have the same problem. The installer is going to pull the unit tomorrow to check the wiring.
Posted Oct 10, 2011 · 11:41 UTC#6
Yeah, the illumination is the orange wire. It is always the orange wire on the factory side, and it is the orange wire (i think it was orange and grey stripped) on the wire harness. It's not hard. Just take the two wires and stripe the wire, tire them together use a connector or electrical tape or both. Boom.
Edited Oct 10, 2011 by Johnny Utah
