I just ordered a Pioneer 920 and went to Best buy to get a labor quote. I have all the parts and the steering wheel control so I will just be paying labor costs. They want $100 for the unit $60 for the steering wheel control and $5 for misc parts fee. So $165 total labor costs. I was wondering if this is reasonable for the unit to be installed. It seems like a lot because I only paid $510 for the unit itself. How is the installation to do yourself? THANKS.
Installation costs
That depends on the vehicle (and how much has to come apart to swap the unit in). For mine ( a 2011 Toyota Tacoma), I would consider it hiway robbery (with wiring harness and nothing other than a head-unit change it's less than a half-hour work).
It's a 2005 Ford Expedition the guy at Best Buy said there's a lot of splicing for the steering wheel control.
it may be expensive, but if you dont know what your doing, then its really not bad, biggest benefit, the labor has a lifetime warranty, so if you ever have any problems, you take it back to them and let them deal with it.
down side, most geeksquad guys wont bypass it.
that being said, an 05 explorer is a pretty easy truck to do, especially if you use a axxess steering wheel control adapter instead of a SWI-PS because they program themselves, as far as a lot of splicing, not really, worse case scenario, you need to tap ACC power, ground, and a resistance wire, some of the ford harnesses need you to take one of the wires and ground it out, then program and plug it in to the radio.
In my 2007 Z71 Tahoe it cost me $239. I had a lot of extra work that needed to be done though; i.e. back up camera, pre-wired Bose system, rear LCD screen, back up / parking sensors, and I had them install it with a bypass so I can input addresses on the fly.
You could do this in 30 minutes ?
In a Tacoma with suitable wiring harness connectors, yes. It's pop off the climate control panel, undo 4 bolts, pull the unit, unplug wires, and reverse. Keep in mind Metra makes a pre-made wiring kit for the Axxess ASWC for the Tacoma, no splicing, no soldering, no guess work of which wire goes where.
^^^ basically if you stare at a toyota long enough, the car will actually install the head unit itself, it also doesnt hurt that the ASWC programs itself and all you have to do is plug it in. hell the longest part of the job is running the mic if you dont dont do VSS or reverse (unless of coarse you get the harness that does VSS and REVERSE for you)
I think I will just do the unit for the $100 labor and wait and see if I want the steering wheel controls later for the $60. Thanks for the replies. The bypass looks super easy to do so I think I will just do that before I have them install the unit.
If you have the correct wiring harness adapter and module for the steering wheel controls it is easy. The only problem I had was programming the buttons on the steering wheel, wiring and installation was easy though.
Best buy is a rip off i they gave me that same quate 99.99 is there price for advance DVD navi install 60 for steering wheel controls
weather they do it at the time the radio is already out or if you come back a month latter there price is always the same on that kidn of sucks i can see 60 since they have to remove the radio
but at the same time as they are already have the radio out for the install i think they should nock price to like 35 or 40
but here is the kicker also
when you get there you are told 20 to run your Ipod cable 20 to run your BT Mic
and 20 for each other ecesory that needs to be run unless its a back up camera then its even more because its more work for them to do
but they quated me over 200 i told them to scram lol
thats interesting, when you tell somebody to scram, you are telling them to "go away" you were in their shop, where were they supposed to go?
as far as it being over priced, thats their price, if you dont like it, then you dont have to get it. however in our town, the three custom shops actually charge more that BB/Geeksquad, and the only two shops that are cheaper, are tinting and detailing shops that also do installs (and twice ive had people bring their installs to me to fix them and their way of connecting the wire harnesses was to twist and tape)
also try to find a shop for less that will warranty their work for the life time of the car, and at over 1,200 locations nation wide. then reinstall the factory equipment when you get rid of the car. if you think that is a high price, try asking asking a dealer, they will tell you its at least three hours on the books @ $100 per, and that is just for the radio with no peripherals.
well basically they knew i was saying take there price and shuve it
im sorry but
you don't advertise a price and then charge More to install options that come with the Unit itself
now i can see if the Mic and the ipod cable where add on options that did not come in the box with the HU
and if the VSS wire was not needed to operate correctly then yeah i can see them charging those
but the stuff came in the box or needed to be hooked up
so there 100 dollar price for install they advertise should have been the price not plus 20 and 20 and 20 more for things that come in the box with the HU
again yeah the price is fine and dandy if that is what they are charging and you buy options that don't come standard with the Unit
but if they come in the box with the unit there price should be for installing that unit
if they don't like that then they can talk to the Manafature and have something labeled specialy for Best Buy or something where they don't have the ipod cable and the BT Mic included in the unit and they cahrge extra for those and all
but you don;t charge someone 100 dolalrs to install a dvd hu or navi hu and then say if you want it to work properly you have to pay us 20 bucks more to run the VSS or if you want your ipod cable plugged into the back of the HU thats another 20 or if you want your BT cable plugged in thats 20
Best Buy sucks!! I would never let them touch my car, even if it is cheap. Best Buy doesn't require people to be certified to do installs as far as I know. Sure I paid like $300 to get my unit installed, but it was well worth it.
where do you live that this is the case???
even you agree that they are optional items,
if you go to a hot rod shop and have a supercharger put on your car, they are going to charge you more to have the fuel system upgraded to feed the blower, then they are going to charge you more to tune the motor so its not a moving grenade. adding options adds to the amount of work being done, and therefore should add to the price. just because they include one optional part in the box (that almost every company charges you more for), doesn't mean that it should get installed for the price of "on the house".
for instance, take the alpine CDE-124SXM. which is a CD receiver and a XM tuner packaged together. separately the deck cost $200 and the XM tuner cost $70, but if you buy them together it cost $230, so you save a few bucks by buying them together. now the labor for a deck install is $50 and the labor for sat install is $60, now its no less work whether you want the package deal or you want a slightly better alpine deck and you buy the two parts separately, so why would the price be over 50% less just because they came in the same convenient box? if it was then you would just be fleecing everybody that bought them separately. you are paying for a service (or most times multiple services), they are just better at having a fair pricing system.
also then everybody that bought from a brand that didn't include the ipod cable(which is far more often the case), would be paying the same price just to have less work done.
again how many boxes there were, does not change how much work was being done. there actually shouldn't be a charge for the mic and VSS as they are a part of the main system, and are needed for proper use.now i can see if the Mic and the ipod cable where add on options that did not come in the box with the HUand if the VSS wire was not needed to operate correctly then yeah i can see them charging those
there is actually not SKU for either of those items, because there is not a service to just install them. there is however a SKU for running a ipod cable (or other media device, of course) as that is an optional device to the unit, and will fully function great with out an ipod.
again yeah the price is fine and dandy if that is what they are charging and you buy options that don't come standard with the Unit but if they come in the box with the unit there price should be for installing that unit
again where does how many boxes you buy, equal how much work you are asking for?
so then you want pioneer to go through the trouble of making special packaging just for one retailer, you do realize that this will add to the total cost of manufacturing right, and this cost will not be just lost to pioneer. can you guess who the cost will actually effect, yup thats right, the end user (pssssss. thats you by the way) will pick up any added cost. do you really want to tax yourself anymore than you have to?if they don't like that then they can talk to the Manafature and have something labeled specialy for Best Buy or something where they don't have the ipod cable and the BT Mic included in the unit and they cahrge extra for those and all
again, it is wrong for them to charge you for VSS and for the BT, and it is part of the scope of work. instead of throwing out diarrhea of the mouth, "well basically they knew i was saying take there price and shuve it" , had to talked to them, thye might have given you a break, and helped you out, i know if i have a customer that is pretty cool, and i actually want them to come back, i sure will, but the people that act like dicks, can either pay the piper, or go kick rocks, and hope the guy that does it for crack head prices doesn't torch their car down.but you don;t charge someone 100 dolalrs to install a dvd hu or navi hu and then say if you want it to work properly you have to pay us 20 bucks more to run the VSS or if you want your ipod cable plugged into the back of the HU thats another 20 or if you want your BT cable plugged in thats 20
well good to see how much you know, that way we can disregard most of your "facts"Best Buy doesn't require people to be certified to do installs as far as I know.
actually BB has pretty much constant training all year long to keep up to date with changing technology, a good part of this training either comes directly form the manufactures or is indorsed by them, all techs must pass a in house certification before they are allowed to even work on cars alone (this certification is designed by a group of MECP master installers) then it is a job requirement that you must actually get MECP certified with in 90 days of being on the job.
there you go OP, BB isnt crazy over priced, but having a qualified person do the job right, is well worth the price they ask.Sure I paid like $300 to get my unit installed, but it was well worth it.
on a side note, only an idiot would say that any person is a worthless installer just because of where they work. by the same means, a place that charges more than another place does not mean that they have better installers. even some the best shops have hired bad installers. bottom line, you should only have somebody work on your vehicle that you trust, and the only way to figure that out is to go out and talk to the installers. and see for yourself, then you will be equipped to make those kinds of decisions.
there are roughly a little over 200 master installers nation wide, and the Geeksquad employs almost half of them. are there a few installers that work for best buy? well of course there is, no company can have thousands of techs and not have a couple of bad ones that havent been fired yet. but there is also a damn good chance that you will find a damn good tech their, just like every other shop ever opened.
the only time i would ever let best buy do a install on my car is if i just have speakers installed and i am just to lazy to do it myself and ill pay there 69 for set for the install cause i know if they screw something up thats what insurance is for
@1loudls
I live in Cleveland Ohio and it comes back to sounding like you are one of the BB workers trying to excuse the reason why they charge it
yes these are options that the HU comes i with
BB chooses to sell them togethere they also choose not to take part in Mail In Rebated the Pioneer offers because they would have to kick somthing back im betting
they are so cheap that they choose to charge extra to plug things in the HU comes with or the system comes i with
then they should not post a rate to install a system they need to post it all
they are charging 99 bucks to isntall a Navi or DVD unit
but they charge 45 to install a Basic CD HU
where is the extra cost in the install labor is the same if they are going to charge more they plug a harness in splice the wires together emaybe a navi or dvd uni has a few more wires then a regular HU maybe they don't
but if they want to charge more for a DVD or Navi install then that should include the options like feature the thing comes with
other wise they can have evyerhign packaged seprate and choose to sell them seprate
but if our units need something to work properly like a VSS wire im sorry i don't belive they will work the way they are desihned without this then why are they charigng 99 to install a unit and then charge more to make that unit work right ? thats really messed up
sorry but what do you do work for BB so you have to stick up for them ?
and see your so much brighter than i give you credit for. and i'm offering you an explanation not an excuse for the charges. no one ever told you you had to pay those prices either, did they? thats the price they offer their services at, you are more than welcome to go to another shop and pay more or less if you want to. god bless America. you dont see me coming so your place of work, and slapping the fry scoop out of your hand and telling you that your dollar fries cost too much, because im too lazy to cook for myself, now do you?
best buy doesn't chose to sell them together, pioneer chooses to package them together. I see you still have a little trouble trying to figure out how exactly how many boxes something comes in changes how much work needs to be done. and i see your right, we shouldn't sell some of our manufactures products just because of what they include in the box.yes these are options that the HU comes i with BB chooses to sell them togethere
well your half right, BB does choose not to take part in any mail in rebates, because they work out back end deal with the manufacture to pay full price for the radio's, sell them with that amount off, and then let the manufactures reimburse the company for the units sold during the rebate period. this way you dont have to do anything for the rebate, you just sit back and enjoy. there are sometime when the manufactures dont quite work out a full rebate because of thisthey also choose not to take part in Mail In Rebated the Pioneer offers because they would have to kick somthing back
fist off a basic deck install and a indash mobile video install are not the same and should be priced differently, the main difference being that the indash also has a reverse wire, a VSS wire, a mic, and GPS antenna. those extra things are why it cost twice as much, because it easily is twice the work. the other thing is that not all systems are the same, not all cars are the same, I still dont see you reasoning behind thinking that every install should cost the exact same no matter how much work has to be done, where is the fairness in that, if you buy a $50K+ car that has a crazy stupid factory audio system with multiple amps that takes most of the day to integrate with, you should have to pay more than the guy with a beat up 2000 civic that can be slapped in in an hour or two. same goes for which radio you buy, there is no way i'm gonna charge the same amount for an install for a guy that buys a AVH-3200DVD that just need to have reverse, and E-brake wire hooked up and a guy that buys a jensen radio that also comes with a HD radio tuner, ipod cable, and a TV tuner. those are no where near the same amount of work and it would be unfair to charge the same.but at the same time, everyone want to see what the cost is and may not want to talk to somebody about it, so the least we can do is get an idea of what the price will be. it also say "Some installations may require additional charges*" on the website and in the store, so i guess i really dont know what else you expect, this is the exact same reason we provide a written estimate once we see the car and whats going inside it, and funny enough this is how every other shop in the world works whether it be a audio shop, dealership, or even a home contractor. how about his, you come up with a much better business plan, and when it provides to be a success, we'll adopt it.then they should not post a rate to install a system they need to post it all they are charging 99 bucks to isntall a Navi or DVD unit but they charge 45 to install a Basic CD HU where is the extra cost in the install labor is the same if they are going to charge more they plug a harness in splice the wires together emaybe a navi or dvd uni has a few more wires then a regular HU maybe they don't
i alsread said that they should be charging you for the VSS and stuff, there are a few exceptions, for instance, if the signal wires will take an unusually long amount time or work to accomplish (i'm sorry if you buy a difficult car to work on, then you better be ready to pay extra for everything you want to have done to it) but again it isnt wrong for a shop to charge you accordingly depending on your scope of work.but if they want to charge more for a DVD or Navi install then that should include the options like feature the thing comes with other wise they can have evyerhign packaged seprate and choose to sell them seprate but if our units need something to work properly like a VSS wire im sorry i don't belive they will work the way they are desihned without this then why are they charigng 99 to install a unit and then charge more to make that unit work right ? thats really messed up
you also seem to constriction yourself
but then you are there trying to get them to install your nav and SW interface, which is it? at first you are ok with them doing the job, but then after you dont like the price, they are not good enough for you, weird how that works out. why dont you just suck it up and do it yourself? then you wont have to spend any money on labor.the only time i would ever let best buy do a install on my car is if i just have speakers installed and i am just to lazy to do it myself
why yes i do work for them (i would seem to have an aweful lot of information as to how they work if i didn't) but its not so much sticking up for them as it is correcting a lot of the incorrect information that is put ot against them. am i not allowed to have pride in my work and in my shop?
again what do you do work for BB
? you defend them like you are a installer yourself
no reason in the world for them to charge to hook up things that come with the HU
if they came sepratly and where purchased options then ok but they where not
again what do you do work for BB?
well now I can't tell if you are illiterate or just plain stupid.
ummm, have you even been reading this thread, or do you just get either board or confused after the first few words?
i spent about $8 on the dash kit and wire harness, about $5 on paint to paint the dash kit the right color, and then spent about 5 hours doing the install.
