2006 Mustang GT VSS
By Louisiana_CRX · Jan 18, 2007in Vehicle Specific Wiring💬 17 posts👁️ 5,567 views
Posted Jan 18, 2007 · 21:40 UTC#1
I have a 2006 Mustang and am trying to locate the VSS wire...they changed something in 2005 so it isn't in the computer box any longer. The site listed for the cruise controls was no help either. Also I'm in search of the reverse or back up wire. Any info to where these wires are and the color I need to find would be appreciated. I have the AVIC 6800DVD changer but I'm trying to hook up the Pioneer vehicle processer and need these so it can calibrate...Thanks...
Posted Jan 18, 2007 · 21:42 UTC#2
speed sense = dk. blue/yellow PCM, top plug, pin 3 The PCM (Powertrain Control Module) is in the front passenger side of the engine compartment.
Posted Jan 18, 2007 · 21:44 UTC#3
reverse = white/yellow PKP or SJB, gry 52 pin plug, pin 13 The SJB (Smart Junction Box) is in the passenger kick panel.
Posted Jan 18, 2007 · 23:16 UTC#4
If you have the shaker system, it will be at the radio.
Posted Jan 19, 2007 · 02:46 UTC#5
I have the Shaker or had the Shaker 500...Will the wire color still be the same? Thanks
Posted Jan 19, 2007 · 02:49 UTC#6
Should be. If not look for a gray/black wire.
Posted Jan 19, 2007 · 20:34 UTC#7
I just checked behind the radio all those wires are accounted for ..there isn't one left over or that matches the color...
Posted Jan 19, 2007 · 20:38 UTC#8
There is a plug with a white/orange and a pink/orange only two wires...I beleive that went into the shaker as well it could be one of those two...I located the Blue/yellow wire in the pcm up front...but that one will be trickey to access....
Posted Jan 20, 2007 · 00:45 UTC#9
RAN into a PROBLEM :( Something touched behind the dash....the Acc. wire is dead. I've checked fuses in car and under the hood. Fuses dead in car not blown. Also no power windows. The auto part of window that seals is still working where it goes down when you open the door a little and raises back up when you close doors. But switches dead and fuses in passenger kick dead for radio.
Posted Jan 20, 2007 · 00:50 UTC#10
most likely a fuse you havent checked, not just the "radio" or "audio" fuse. Check them all
Posted Jan 20, 2007 · 01:02 UTC#11
I ran the meter over all of the standard mini fuses with no luck 3 times...all the fuses in front and in the under hood fuse box. It was getting late I'm gonna go over them all again tomorrow...I'm not sure how to check the bigger square fuses. They have a little window and nothing looked blown. It is hard for me to think one of those could've blown.
Posted Jan 20, 2007 · 01:13 UTC#12
If the fuses are metering good, then pull them out and visually inspect them. I've seen fuses meter as good, but are actually bad...
Posted Jan 20, 2007 · 01:46 UTC#13
If it is decent weather tomorrow I'm gonna check into that....I did try unhooking the battery for 5 minutes and hooking it back up with no luck...And so far I haven't found anything else not working...I've checked keyless...cruise....power locks...wipers...dash lights.....power seat...blinkers...horn....hazard.....auto dimming interior.....everything else seems to work...
Posted Jan 20, 2007 · 16:30 UTC#14
Found a bad fuse a 5amp ? Listed under accesory delay feeds ....Ford seems too cheap to provide spares....and size has changed so no robbing one off my 96. I pulled the pwr mirror fuse to replace temporary. I'll buy some spares later after I rewire things....Windows and accesory lead are now back working...:)
Posted Jan 20, 2007 · 16:36 UTC#15
good job, that is typical of fuse box routing. be sure not to short it out in the meantime. maybe keep it pulled until your done with your avic and such install.
Posted Jan 20, 2007 · 18:46 UTC#16
But tracking down blown fuses is fun! There's nothing I love more than going through 3 or more different fuse panels to find 1 bad fuse....
Posted Jan 20, 2007 · 19:44 UTC#17
ohhh boy
