I had a brief run through the forums and I couldn't find any information regarding my problem, so here goes:
My AVIC D1 works flawlessly except for when I try to plug any kind of external video into it. Whenever I plug any kind of RCA plugs from any source, the picture comes through very distorted and I get a buzzing through the speakers. If I remove the video cable, the buzzing goes away and I get clear audio. I also tried getting video through the rear camera in & the same thing happens. The harness itself looks physically fine, and there is no continuity through the cable itself from + to - so it would appear the cable is fine. I tried plugging in another D1 and the same thing happened, but it was still using the same RCA harness.
So my question is, is this a known issue? Is there a setting that needs to be changed? Just weird that i'd have the same issue with 2 seperate units (however running the same RCA harness).
I have verified that all my sources & source cables are in proper working order.
Any help on the issue would be appreciated,
