HELP! Broke the mute wire while trying to remove it from the harness...
By MGCustoms325 · Oct 03, 2011in Problems/Troubleshooting💬 3 posts👁️ 1,211 views
Posted Oct 03, 2011 · 09:06 UTC#1
Hi AVIC 411 Users,
I was attempting to remove the yellow mute wire before installing my Z130BT and I broke the wire. Is there anybody that has had this issue and purchased another harness with compatible leads? I would be interested in purchasing up to 3 of these independent wires that have been removed from the harness. Please let me know if you can help me out. Thanks!
Posted Oct 10, 2012 · 23:34 UTC#2
I have this same problem. Unsure if I should buy a whole new harness and try again or if the wires can be purchased separately.
Posted Oct 11, 2012 · 01:34 UTC#3
this is old, but i have mentioned in another thread, if you can find an old broken pc powersuppy with the smaller 4-pin floppy drive connector, those pins work great in the a/v connector...
