Hi
Can you guys tell me is there any hacks for F30BT?
If so, witch?
hope you guys can help me out
/Providers
Hi
If so, witch?
/Providers
hmm, no anwsers.
If I want to bypass it,
Should I then ground handbrake wire and move mute pin like they write in this post
http://avic411.com/index.php?/topic/14761-avic-f-series-bypass-picture-guide/
please help me, I recive my new unit tomorrow
Hi Providers.
I have also got me a F30, I wonder if you have managed to bypass the unit? ![]()
please check z-series for z130bt (us version) for hacks
I did the bypass hack on my F30BT, moved the mute wire (yellow-black) to the pin straight up or down depending on how you are holding the connector in front of you
It's working fine
Hi can I put any map to avic f30bt
Thanks, worked perfect.
