did i mess up my power harness ? part broke off when i was trying to move the mute wire
By ThumperPup · Oct 13, 2011in Hacks/Mods💬 8 posts👁️ 1,398 views
Posted Oct 13, 2011 · 23:39 UTC#1
did i mess up my power harness or will it still work i am able to snapp the white plastic part back on no problem
but when i was trying to move the mute wire
the plastic part just broke off
i plugged it into the unit to make sure it fit nice and snug still and it does
but did this one plastic part breaking off damge the rest of my harness ?
or am i still ok ?
Posted Oct 13, 2011 · 23:41 UTC#2
also i just can't seem to get it out so i am thinking maybe of finding something thin enough to fit in the small holes on the harness and push the plug out going in from where it would plug into does that makes seance anyone know what is small enough to fit in there ?
Posted Oct 15, 2011 · 13:52 UTC#3
This video shows how to remove the wire with less hassle by using something to insert in the harness from behind.
Posted Oct 15, 2011 · 14:01 UTC#4
yeah i found that after watching the other one
how ever that video didn't show anything about grounding the other wires together wich made me think maybe that was not the correct process but i did use a paper clip to push it out out and then i moved it down one spot
and when i put it in i put it in nice and snugg i hear it click and it is just as snug as it was before i took it out so im confident i did it correctly
im just wondering if i messed up the harness plug itself when that broke but since the plastic part snapped right back on and it plugs in to the unit without an issue nice and snug im thinking it will be fine
Posted Oct 15, 2011 · 15:27 UTC#5
If you're that worried about the harness, why not just glue the piece back on with krazy glue or something?
Posted Oct 15, 2011 · 15:33 UTC#6
i wouldn't say im totaly worried i am just asking if i screwed it up
or does that plastic not affect the way it works
i can snap it back in and it stays in but not with as much preassure as it had
so did i mess it up am i going to have a problem with the harness or is it going to be ok
Posted Oct 18, 2011 · 13:32 UTC#7
As long as the pin still snaps into place securely then you're fine.
Posted Oct 18, 2011 · 15:07 UTC#8
cool thanks
