Pink speed wire
By mike17 · Oct 14, 2011in Hacks/Mods💬 8 posts👁️ 2,691 views
Posted Oct 14, 2011 · 02:28 UTC#1
I have just received a x930bt. I am doing the install this weekend. Do I need to run the punk wire from the harness anywhere?
Posted Oct 14, 2011 · 02:42 UTC#2
i am not sure but i think that wire you are talking about is the VSS vehicle speed sensor wire
Posted Oct 14, 2011 · 02:48 UTC#3
That is the wire I am talking about. From what I am gathering it just makes the gos speed more accurate. I am just curious if I can just leave it be and not hook it up.
Posted Oct 14, 2011 · 03:35 UTC#4
id like to know this also
i think someone ones told me that its there for say if your going threw areas that might not easily pick up a gps signal it will make sure it keeps you on rout with where you are untill you pick up a good signal it also is for when you go threw tunels or somehting like that where there will be no signal it can be there to tell you how fast your going
Posted Oct 14, 2011 · 03:43 UTC#5
This is your vehicle specific question, most of the cars have this signal connected to factory HeadUnit, it is used to adjust volume according to the car's speed.
Edited Oct 14, 2011 by Ralpharn
Posted Oct 14, 2011 · 13:29 UTC#6
I do not have this built in to my factory harness. Any idea where I could find out where this wire is?
Again, is this necessary to hook up?
Posted Oct 14, 2011 · 16:27 UTC#7
It (the vss wire) is not necessary to hook up. It helps with maintaining position when GPS drops off due to a tunnel, tall bldg etc. It may help with an Automatic Sound Leveling scheme (increase volume at higher speeds - don't know would never use such a thing if it's there).
Regarding finding it, it varies by car. In my case (2011 Tacoma) there was a wire coming off an interior fuse block I was able to tap into and get the VSS signal.
Edited Oct 14, 2011 by lbridges
Posted Oct 14, 2011 · 18:58 UTC#8
yes it does verry by car
my VSS wire on my car comes out the dash cluster itself in the plug that plugs into the left side of the dash cluster this is on all 98-01 cadillac sevilles
in 2002-04 they switched it and put it in the harness itself like mentioned above
