Avic-Z2 (starting pioneer navigation) Help!!!!
By turbonaticsracing · Oct 14, 2011in Problems/Troubleshooting💬 4 posts👁️ 1,259 views
Posted Oct 14, 2011 · 04:02 UTC#1
Hi guys I just recently got a z2 and after installing it last night the screen goes no further then "starting pioneer navigation". I was wondering if anyone has any clue to what i might be doing wrong. I'm installing it in my 04 altima and all the wires seem to be straight forward. The only thing that is not installed and I don't have is the gps thing, so I don't know if that has anything to do with it, if so is there a bypass mod. I'm only using as a normal stereo no amps subs etc.
Posted Oct 14, 2011 · 12:10 UTC#2
Sounds like a software or hard drive issue. It could also be the z2 firmware "freeze". Try power cycling it a few times to see if it will start. Your wiring can not cause this to happen. You can completely boot the unit by only connecting yellow, red, and black...
Posted Oct 14, 2011 · 17:54 UTC#3
I actually have no idea if it will start up without a GPS antenna connected ... Don't you have one to (temporarily) connect, to see if that solves the problem ?
Posted Oct 14, 2011 · 18:53 UTC#4
Yes, it will completely boot without the GPS antenna connected. You only have to connect YELLOW (+12v), RED (+12V), and BLACK (-12V ground).
