Z130BT Traffic Tuner Issues
By heyredy141 · Oct 15, 2011in Problems/Troubleshooting💬 10 posts👁️ 3,312 views
Posted Oct 15, 2011 · 12:22 UTC#1
Hello,
I got Avic Z130 BT installed in my car but I noticed that I do not get any traffic updates or HD radio in my area. I am not sure if I have HD radio in my area but I am pretty sure that I have traffic updates in my area as per the below. But whenever I go to Traffic icon , it says no available providers. I am not sure if this is an installation issue. Please help.
http://totaltraffic.com/CoverageAreas/CoverageMap.aspx?MarketUid=bf2d6a2c-61c1-4932-ad65-b4441ed564ef
I am also not sure if Z130BT DAB radio compatible. I know that some stations near me broadcast in DAB.
Thanks in advance
Posted Oct 15, 2011 · 13:54 UTC#2
whyll the topic is on here i was wondering
i thought i read somewhere on pioneer website starting the end of this year or begining of next year the traffic tunner would not work anymore or something like that
Posted Oct 16, 2011 · 06:21 UTC#3
I am not sure about that. Do you know if this is really the case? Can you direct me to the info as Pioneer did not mention anything about it when I called them but they did not seem to know anything about their product anyways.
Posted Oct 16, 2011 · 12:23 UTC#4
That's the old MSN based traffic tuner. It is not even supported on a Z130. It has nothing to do with the new RDS based traffic system.
The traffic data for this is fed by Clear Channel FM stations in the US and it is free for Pioneer tuners. I don't know how it works in Canada. In some parts of the world it is subscription based. But Pioneer support should already know this.
Edited Oct 16, 2011 by RonS
Posted Oct 16, 2011 · 16:48 UTC#5
Thanks for the response. As shown in the below link it is available in Vancouver, Canada but does not seem to be working. It keeps saying no providers available. Any ideas on what might be the cause?
http://totaltraffic....65-b4441ed564ef
Edited Oct 16, 2011 by heyredy141
Posted Oct 17, 2011 · 23:39 UTC#6
For benefit of others, if you face the same issue as mine then please verify the below.
• Press the “HOME” key
• Select the “Settings” tab
• Select “System Settings”
• Select “Service Information”
• Press and hold the upper left corner of the “Service Information” screen for a few seconds
• The "Platform Version" number and the "Application Version" number will be displayed --please look at
the "CAN " number, which is displayed at the bottom of the screen
If this is dashes, then it means one of 2 things. 1) Installation was not done correctly 2) the tuner is defective.
CAN shows the version of traffic tuner. If this is blank means that the unit is not detecting traffic tuner.
Posted Oct 18, 2011 · 00:19 UTC#7
Is this documented anywhere in the installation instructions or in a link somewhere. I'd like to show my installer.
I have all -------- at the CAN number. Tthey've had the unit out a couple of times sorting out a few things, now my AM and FM reception is spotty and no RDS provider is shown on the Traffic Tuner. I know for sure that the it used to show the RDS provider. I think something came loose or the didn't hook it back up right.
Posted Oct 18, 2011 · 00:25 UTC#8
I got this info from the Pioneer Support center when I talked to them over phone. So, this is not documented anywhere else. Like I said, CAN refers to the version number of the tuner. If that is not detected, it means that the traffic tuner is not hooked up correctly or the traffic tuner is defective.
Posted Oct 18, 2011 · 02:28 UTC#9
OK, thanks. I appreciate the info.
Posted Feb 22, 2012 · 04:44 UTC#10
Im having the same problem. I have a z120BT upgraded to Z130BT and when my driving drections are in route, if i click "traffic flow" it says "no data." What do I need to do to get this workig correctly?! Please help, thanks in advance.
P.S. sorry I high-jacked your post :?
